TT Paul Posted March 26, 2017 Share Posted March 26, 2017 No leaks or oil etc in area. It's a new turbo blanket is it normal for this to smoke a bit. Only just fitted it to. Searched Google seems some do when their new just seeing other people's views? Link to comment Share on other sites More sharing options...
berg Posted March 26, 2017 Share Posted March 26, 2017 Mine did that thought something was on fire It will stop Although it can look worse if its a combination of the blanket and oily hand prints on the turbo/manifold if youve been doing work in that area Link to comment Share on other sites More sharing options...
Gpro Posted March 26, 2017 Share Posted March 26, 2017 Yes it's perfectly normal. Drive the car on the motorway and do a few WOT pulls to hit high temperatures. It should bed in and stop smoking after that. Link to comment Share on other sites More sharing options...
TT Paul Posted March 26, 2017 Author Share Posted March 26, 2017 Yes it's perfectly normal. Drive the car on the motorway and do a few WOT pulls to hit high temperatures. It should bed in and stop smoking after that. Sweet cheers. Link to comment Share on other sites More sharing options...
TT Paul Posted March 26, 2017 Author Share Posted March 26, 2017 Mine did that thought something was on fire It will stop Although it can look worse if its a combination of the blanket and oily hand prints on the turbo/manifold if youve been doing work in that area /QUOTE] Cheers berg. not been oily around area just was like wtf and pulled blanket off which was a tad hot. Link to comment Share on other sites More sharing options...
TT Paul Posted March 26, 2017 Author Share Posted March 26, 2017 Sweet cheers. Just dramatic when you see smoke. Link to comment Share on other sites More sharing options...
JackyBoi Posted March 26, 2017 Share Posted March 26, 2017 Same happened to me when I first fitted DEI heat wrap but the smoke disappeared after a couple of heat cycles Link to comment Share on other sites More sharing options...
SupraLEDrears Posted March 26, 2017 Share Posted March 26, 2017 Mine was a bit too big and touched the manifold so check for that too Link to comment Share on other sites More sharing options...
Sheefa Posted March 26, 2017 Share Posted March 26, 2017 Ditto. Needs to run a few full heat cycles first mate Link to comment Share on other sites More sharing options...
