Low level Oil light
Jellybean
Hi
Below was all done in 2015 , Cam seals in 2011; No smoke on start up , all looks good ; had a couple of spirited drives since she was back on the road start of the month (March 2017)
Was fitting some stereo equipment today , brought her up to temp messing with the stereo , turned off , had some lunch (40 mins), went back dow, to head out for a drive ; Low level Oil light ,
dipped her , nothing on the dip stick , no signs of an oil leak , Parking spot has no fresh oil stains
must be about 700 miles since last oil change (10W60 fuchs), any idea's what would cause the oil consumption?
Engine
Tbelt
Gates Racong Kevlar TBelt
Billet Timing Belt Tensioner Bracket
TENSIONER ASSY, CHAIN, NO.1
IDLER SUB-ASSY, TIMING BELT, NO.1
Cams
Cam Seals
Valve Cover Seals
Outer Cam Valve cover Bolt set SS
Valve Cover Washer Seals X 16
Water Pump
Water Pump + Housing
RING, O(FOR OIL PUMP) No.1
RING, O(FOR OIL PUMP) No.2
Oil Pump
Oil pump,PUMP ASSY, OIL
Oil Pump Front main Seal
1X Black Toyota Black Sealant
Top it up and keep a eye on it?
That's what I did , took her out for a spin and a few pulls , waiting for it to cool down to dip her
She's running great , every feels normal , no smoke , strange smells
Might be those after market valve covers , rear an exits do sit low
I know sitting up doesn't help seals either
Get someone to follow you. Then go WOT and they can tell you if any smoke. Normally quite hard to see from side mirrors unless you are chucking out smoke.
What condition is your oil in, is it black? Any smell?
Fuchs red , no smell , cams are covered in fuchs red inside the valve cover
O ring on the dip stick might be worth changing
