nolizma Posted March 20, 2017 Share Posted March 20, 2017 Hi I was looking at boost controllers and came across that. https://www.amazon.com/Innovate-Motorsports-SCG-1-Solenoid-Controller/dp/B00LBJAZLI Has anyone used it? My understanding is that this works as boost and afr gauge plus as a boost controller and even has a shift light too. I find it appealing as theoretically you can just use that and keep a clean cabin without a million gauges. Will this work with the stock ECU? (TT) Cheers Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 20, 2017 Share Posted March 20, 2017 Interesting! i have used Innovate stuff a lot in the past, always works well and reliable, that's quite a good idea, its a stand alone boost controller then it has no interface with stock CU so no problem, it will also integrate with there data loggers. Link to comment Share on other sites More sharing options...
Glanza_Mike Posted March 20, 2017 Share Posted March 20, 2017 I have this mate and i really like it, i made a bracket for it to fit nice and snug in the old facelift clock position. Gauge looks great, boost controller and wideband seem to both work very nicely. And looks kinda stock where i've put it in the black colour I bought this as i didn't want loads of gauges. Link to comment Share on other sites More sharing options...
nolizma Posted March 20, 2017 Author Share Posted March 20, 2017 That's great! Thanks Mike! What sort of bracket did you have to make up? Is it not the size of the clock? Link to comment Share on other sites More sharing options...
Glanza_Mike Posted March 20, 2017 Share Posted March 20, 2017 Yeah same size as clock mate but the backs smaller so there's nothing to hold it in that spot as tight as i wanted. So i bought some L brackets from B&Q cut them to size and they screw into the standard clocks screw holes. More info in my thread i did a little write up on it: http://www.mkivsupra.net/vbb/showthread.php?312085-Glanza_Mike-s-Clean-White-VVTI-Supra-Project!/page15 Link to comment Share on other sites More sharing options...
nolizma Posted March 20, 2017 Author Share Posted March 20, 2017 Yeah same size as clock mate but the backs smaller so there's nothing to hold it in that spot as tight as i wanted. So i bought some L brackets from B&Q cut them to size and they screw into the standard clocks screw holes. More info in my thread i did a little write up on it: http://www.mkivsupra.net/vbb/showthread.php?312085-Glanza_Mike-s-Clean-White-VVTI-Supra-Project!/page15 Awesome! Seems I missed it when I was reading through your thread the first time. Many thanks! Did you buy it from amazon? Couldn't find a better price anywhere online. Link to comment Share on other sites More sharing options...
