New Wheels 20" Rear 19" Front HELP!
GreekSupra
Hello guys,
Need some help here:
Getting my Supra on the road in a few days, need some nice Wheels with Michelin Pilot Cup 2
I decided to go with this:
http://www.nicheroadwheels.com/misano-m117-w-19769.htm
Front:
19" 5x114.3 - 8.5" - 245/35/19 - Offset: 45
Rear:
20" 5x114.3 10.5" - 305/30/20 - Offset: 30
Can you please let me know if they will fit?
My arches are rolled already.
Thank you guys
305 tyre on a 10.5" wide rim is too wide really, should be 295 max, better still 285 or 275
Says who? GTRs run 305 rears on a 10.5J rim which is actually the recommended setup from Litchfield, some even go to a 315.
Ive got 305 Cup2 rears on a 10.5J rim right now its fine.
Just about every tyre size guide i can find says 275 285 are the best size on a 10.5" wide rim with 295 being the max
Do you know what size wheels are fitted to your car now ? if you do then you can use this site to help
http://www.willtheyfit.com/
Compared to stock 17's
9.5" x 20 with ET 35 are as below
http://www.willtheyfit.com/index.php?width=235&aspect=45&diameter=17&wheelwidth=8&offset=50&width2=245&aspect2=35&wheel_size=20&wheel_width=9-5&offset2=35
the 10.5" x 20" with ET 30 are as below
http://www.willtheyfit.com/index.php?width=255&aspect=40&diameter=17&wheelwidth=9.5&offset=50&width2=295&aspect2=30&wheel_size=20&wheel_width=10-5&offset2=30
Personally i wouldn't go any bigger than 19's
I dont think you will get a 295 tyre on a 10.5j et30 either unless you are standard height or run silly camber
For reference this is my 10.5J et30 with a 305/30/19 tyre which does not fit the car
This needed a 275 tyre to fit behind a rolled arch
