foggy147 Posted March 19, 2017 Share Posted March 19, 2017 Does anyone know if this double din unit would be a straight swap for the Supra? Thanks Kenwood DPX7000 DAB Quote Link to comment Share on other sites More sharing options...
bayside_supra Posted March 20, 2017 Share Posted March 20, 2017 Double din should fit fine Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 20, 2017 Share Posted March 20, 2017 Pretty much all double DIN units fit, but you may need to trim the surround on the back of the dash panel. Quote Link to comment Share on other sites More sharing options...
scorling Posted March 20, 2017 Share Posted March 20, 2017 Fitted a new double din unit yesterday. I spent more time trimming the dash panel to get a good fit than I spent fitting the unit Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 20, 2017 Author Share Posted March 20, 2017 (edited) So I don't even need to purchase an additional cage etc? Any specifiic removal tools (it currently has a single din unit) Edited March 20, 2017 by foggy147 (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 20, 2017 Share Posted March 20, 2017 No, you dont use a cage in the supra (or most Japanese cars of this era) the stock metal radio brackets detach from the existing stereo, and screw into the side of your new unit, using ONLY the correct length screws. If a cage has been used, which I have seen before, it is a bodge. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 20, 2017 Share Posted March 20, 2017 If you're not confident doing this, if you can bring the car over to York at some point I'd be happy to give you a hand fitting it Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 20, 2017 Author Share Posted March 20, 2017 Ok thanks guys. J_JZA80 might have to take you up on that offer! Useless at these sort of things. Treated myself to this unit instead, few addtional luxury features. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 21, 2017 Author Share Posted March 21, 2017 Stereo turned up today, looks like a nice system. In readiness this is the adapter that it has come with, will this be plug and play and if not what will i need to get ordered to ensure a stress free fitting? Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 21, 2017 Share Posted March 21, 2017 PC2-17-4 adaptor mate. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 21, 2017 Author Share Posted March 21, 2017 Thanks Rob, good old eBay £3!! Will that be all I'd need? Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 21, 2017 Share Posted March 21, 2017 Thanks Rob, good old eBay £3!! Will that be all I'd need? Yes mate. What stereo did you have in it before? As most aftermarket headunits work off of the PC2-17-4. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 21, 2017 Author Share Posted March 21, 2017 Its a Goodman's that's currently in a single din unit Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 21, 2017 Share Posted March 21, 2017 Have you taken it out yet? I'd look and see what you have there already if you haven't mate. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 21, 2017 Share Posted March 21, 2017 It probably has an adapter already if it's fitted with an aftermarket stereo. And there's a good chance the connections have been cut in favour of bullet or blade connectors. Don't order anything until you've checked Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 24, 2017 Author Share Posted March 24, 2017 Going to fit the stereo tomorrow, where is the best place to stick on the DAB Ariel? Passenger side pillar? How easy is it to remove the pillar cover to be able to attach it to some bare metal? Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 25, 2017 Author Share Posted March 25, 2017 (edited) ... Edited March 25, 2017 by foggy147 (see edit history) Quote Link to comment Share on other sites More sharing options...
BoGlE Posted March 25, 2017 Share Posted March 25, 2017 Easy to remove the trim. You could run the wire up there and across to the rear view mirror and attach it behind that Quote Link to comment Share on other sites More sharing options...
