Andrew K Posted March 19, 2017 Share Posted March 19, 2017 Is there a way of testing or visually looking inside to see if a diff is either from a 5 speed manual or 6 speed manual N/A? The diff is a factory LSD but isn't on the car and was of a N/A manual that's all I know. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 19, 2017 Share Posted March 19, 2017 You need to count the teeth on the ring & pinion to work out the ratio. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted March 19, 2017 Author Share Posted March 19, 2017 You need to count the teeth on the ring & pinion to work out the ratio. Ok so once you know how many teeth are on the ring & pinion what's the formula for working it out? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 19, 2017 Share Posted March 19, 2017 Ok so once you know how many teeth are on the ring & pinion what's the formula for working it out? Divide the number of ring gear teeth by the number of pinion gear teeth. Quote Link to comment Share on other sites More sharing options...
