Heater Control unit -- Lights Flickering
Jellybean
Lights on the Heater control are flickering , the unit it self is flicking between Recirculation and Non-recirculation (symbol above)
Inside the cabin it is extremely hot all the time as if it is set to max temp, intermittently dimmer lights are coming on/off
Fan and LEDS on the switch work as expected
Will verify the internal Thermostat is hooked up , but any idea's , did not come across anything on here
Common they need re-soldering ?
Edited by Jellybean (see edit history)
The connections on the board can sometimes burn out, id open it up, bridge any connections with thin wire to fix it if it has, seen this a few times including my own. Previous owner wired a seperate switch for AC, my dad opened it up and the AC connector burnt out. Easy fix
block connector was not full pressed in , doh
Few bulbs are gone though and need some new block connectors , plastic clip has lost its tension , bitch to get out
Will just get heckler to do led conversion on the unit and centre cluster over the winter
Thanks for the help!
