Spunkmeyer Posted March 18, 2017 Share Posted March 18, 2017 Small Case low ratio LSD Diff Wanted [emoji6] Link to comment Share on other sites More sharing options...
a98pmalcolm Posted March 18, 2017 Share Posted March 18, 2017 There was a cheap one on FB and ebay recently I think, there not worth massive amounts unlike big case Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 18, 2017 Author Share Posted March 18, 2017 I've only seen 2ways or Torsions in the last week Link to comment Share on other sites More sharing options...
SPG Posted March 19, 2017 Share Posted March 19, 2017 Which small case diff mate? A01B, 2B? Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 19, 2017 Author Share Posted March 19, 2017 LSD (so 2/3B) not 1B which is Torsion - if I recall the advice I've received recently, as I'm after a lower ratio too Link to comment Share on other sites More sharing options...
SPG Posted March 19, 2017 Share Posted March 19, 2017 I'm fairly certain the A01B is LSD, maybe it's the A01A you are thinking of. If it's a TT lump you're running then the A01B makes for an interesting drive, but the A02B is much more usable. If it's a NA engine then the W58 mated to the A01B is one of my favourite combos. A02B would work also but it won't help with regards to lower ratios. Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 19, 2017 Author Share Posted March 19, 2017 I have the 1A open diff on my auto. But I have a W58 conversion. I understood from the search button - 1B is torsion not LSD. It's for track use so I don't want drifty Link to comment Share on other sites More sharing options...
Scooter Posted March 19, 2017 Share Posted March 19, 2017 All the 'B' refs are "Torsen" torque sensing limited slip diffs the only ones that came as standard from the factory. So A01B, A02B, A03B etc etc are all the same type of lsd. you need to look at the new Zealand Mkiv Supra specs page via google it shows all the diff ref's a their ratios wheel teeth etc etc. Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 19, 2017 Author Share Posted March 19, 2017 Thanks will take a look Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 19, 2017 Share Posted March 19, 2017 A01B has a 4.083:1 ratio A02B has a 3.769:1 ratio A03B has a 3.266:1 ratio E2A I believe the W58 used the 4.083:1 ratio but these are as rare as hen's teeth in B diff or LSD. Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 19, 2017 Author Share Posted March 19, 2017 Thanks I'm after a lower ratio so a 2B or 3B as I originally suggested, but I appreciate the explanation over torsions. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 19, 2017 Share Posted March 19, 2017 I believe James had a W58 on a TT with an A02B. Might be worth while taking with him to get some input before deciding on this or the A03B. Link to comment Share on other sites More sharing options...
Spunkmeyer Posted April 14, 2017 Author Share Posted April 14, 2017 Bump Link to comment Share on other sites More sharing options...
Spunkmeyer Posted April 21, 2017 Author Share Posted April 21, 2017 Bump Link to comment Share on other sites More sharing options...
Spunkmeyer Posted May 17, 2017 Author Share Posted May 17, 2017 Bump from March lol Link to comment Share on other sites More sharing options...
Spunkmeyer Posted July 5, 2017 Author Share Posted July 5, 2017 Bump Link to comment Share on other sites More sharing options...
