Best value Orbital polisher
MattP
my machines are probably ott for you as i use them all the time , but the das 6 kit seems to be recommended reading back , look on detailing world , might find a used one but there are companies on there that will supply new .compounds and pads are just as important , can work out expensive if your only going to use it a few times, just keep that in mind
Another vote for the das 6. This is the one i bought.
Decent bit of kit although i must confess to not using it as much as i should.
Should also say i am a complete novice but have found it easy enough to make a satisfying amount of improvement to the black aging black paint with plenty of swirls on my MR2.
http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/das-6-pro-dual-action-polisher-menzerna-intro-kit/prod_720.html
