Odd thing happened
ManwithSupra
Unfortuantly my battery was flat when i tried to start my car, so i got it jump-started no problem with starting it turned over once and started, the odd thing that happend was my instrument lights were going mad, the speedo was going up and down and the slip control light was flashing.
i let it idle for a few mins and everything settled down, then i turned the wheel and the speedo went crazy again, i waited for it to settle down again and then pressed the electric window button, when it wound itself all the way down the speedo went mad again... :looney:
Is this to do with the battery voltage being low or is it a problem that is not related to the battery.
