foggy147 Posted March 15, 2017 Share Posted March 15, 2017 Wanting to order a full set of brake disc and pads, the car has rear J-Spec brakes (1999 NA), and the front have been upgraded to the LS400 setup. Can someone please advise the correct disc sizes/pads so I can get these ordered up? Thank you. Quote Link to comment Share on other sites More sharing options...
boostman Posted March 15, 2017 Share Posted March 15, 2017 Wanting to order a full set of brake disc and pads, the car has rear J-Spec brakes (1999 NA), and the front have been upgraded to the LS400 setup. Can someone please advise the correct disc sizes/pads so I can get these ordered up? Thank you. The ls400 are 315mm diameter and I think jspec rear are 307mm I ordered my ls400 discs and pads from carparts4less, pagid brand. Great quality and good price form there, look for a discount code! Rears are just oem disks and pads, not changed them yet Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 15, 2017 Author Share Posted March 15, 2017 The ls400 are 315mm diameter and I think jspec rear are 307mm I ordered my ls400 discs and pads from carparts4less, pagid brand. Great quality and good price form there, look for a discount code! Rears are just oem disks and pads, not changed them yet Perfect thank you, just ordered all new disc and pads. Hopefully they are the right ones! These were the part numbers I used from carparts4less for the LS400 disc and pads: Pads Part No.: 101820498 Disc Part No.: 104820798 Quote Link to comment Share on other sites More sharing options...
boostman Posted March 15, 2017 Share Posted March 15, 2017 Perfect thank you, just ordered all new disc and pads. Hopefully they are the right ones! These were the part numbers I used from carparts4less for the LS400 disc and pads: Pads Part No.: 101820498 Disc Part No.: 104820798 Yep there the ones! Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 15, 2017 Share Posted March 15, 2017 Awesome you guys!! Just doing exactly the same Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 15, 2017 Share Posted March 15, 2017 I had ordered EBC yellowstuff but Ive been warned ones from early LS400 don't fit the 4pots? Does anybody know this? The year was early 90s LS400 on the pads I've bought direct from EBC Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 15, 2017 Share Posted March 15, 2017 Are the Pagid good enough for fast rd / track use? Quote Link to comment Share on other sites More sharing options...
boostman Posted March 15, 2017 Share Posted March 15, 2017 Are the Pagid good enough for fast rd / track use? /QUOTE] For my na, there fine.... Lots of bite, but not had them fade yet. Probably don't have the power.... Haha Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted March 15, 2017 Share Posted March 15, 2017 I'm NA too just make up for it in braking [emoji38] Quote Link to comment Share on other sites More sharing options...
boostman Posted March 15, 2017 Share Posted March 15, 2017 I'm NA too just make up for it in braking [emoji38] /QUOTE] Good to hear, like I said, fast Road there fine on mine but not taken them on a track or pushed them hard enough to fade Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 15, 2017 Author Share Posted March 15, 2017 (edited) If I were to order braided brake lines, if I order just standard Toyota Supra ones will they be ok with the LS400 front brakes etc? Seen these on ebay - 272563515903 I have used Wezmoto ones on the MX5 and was impressed with the quality. Edited March 15, 2017 by foggy147 (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Cillian Posted March 15, 2017 Share Posted March 15, 2017 I used the standard Toyota Supra front lines when fitting the ls400 front brakes, i would assume it would work both ways? Quote Link to comment Share on other sites More sharing options...
