Protecting underside of supra
Tyson
I'm just about to start tackling surface rust on the car, starting by doing all arches then will move on to the underside.
I've taken the front wings off, archliners hockey sticks etc. And have found some patches of light surface rust beginning to form. had I not stripped as much off it would certainly have progressed and become much more of a headache in future. Well worth being thorough.
I was planning on stripping any rust back and coating with a high zinc content primer, then top coat of paint, and finally some form of rubber based underseal. Is this going to be adequate, or is it overkill?
Not overkill at all, preserve and protect as much as you can :)
Main reason was I was going to redo the wheel arches as you can see a light bit of over spray from when the car was painted so I thought about doing the whole underneath ..
I might just do wheel arches and scooter said there no point really
Looking good Burna !
Cheers
Ok, in brief, remove old underseal, wire brush it all, rust treat it, zinc primer, then upol raptor.
I'm planning on doing a project/progress thread shortly, so people can see the process over the next few years go on, and mainly a record for myself for the future.
I dont envy you that job at all :D
