Apexi air filters, battery clamp, bell housings, torque convertor and more..
Delboy52
Have some Supra related bits to move along. Let me know if anything is of interest. I've added an approximate delivery cost.
- 2 x Apexi filters £40 each. + £8.50 Sold
- Universal Apexi model 500-a021. OD - 160mm, ID 85mm. Very good condition, pratically new.
- Active spoiler ECU - £25 - £3
- 89750-14010
- Facelift clear lenses - £15 + £3
- Automatic shifter rod. TT(jpn), NA, UK - £7 + £3
- 33675-14180
- Active spoiler motor (I recall the turning arm has been set to a slightly different position.) - £30 + £5
- TT Torque convertor - £40 + £10 Sold
- 32000-30250
- Grey sun visors - £15 + £4 Sold
- 74320-14680-B0 LH
- 74310-14610-B0 RH
- J1 Bell housing NA - £40 + £7 Sold
- 35111-22081
- J3 Bell housing TT - £40 + £7 Sold
- 35111-30140
- Prefacelift rear lights with loom and bulbs. Loom has been cut for a fog light conversion (Have some crazzing in the lenses) - £30 Sold (whitz)
- 81550-14660 LH
- 81551-14660 RH
- Active spoiler dash button - £10 + £3 - Sold (haz182)
- 84865-14010
- Supra battery clamp - £10 + £3 - Sold (Marty)
- 74404-14320 Clamp, BATTERY HOLD DOWN
- 74407-14020 BOLT, BATTERY CLAMP
Hi mate, are these UK pre-facelift rear lights? I.e. would they work with the stock UK rear fog light switch plug and play?
/QUOTE]
Hi mate
They are from my Jspec Supra. The clusters share the same part number as the UK rear lights but for the fog light to work it had to be spliced into this loom.
The two looms have different part numbers so I'd expect the UK loom includes fog light function where Jspec doesn't?
The Jpsec RH loom is 81555-14660
The UK RH loom is 81555-14680
I have facelift rears also and the prefacelift bulbs were too big to fit into the facelift cluster openings as the spec changed. If you want to keep the facelift rears you'd have to do the fog light conversion as a UK loom would use the older big bulbs.
This is a very good guide which worked perfectly for me. Can most likely use your OE fog switch to control it:
http://www.mkivsupra.net/vbb/showthread.php?80479-Fog-Light-Conversions-for-beginners
Thanks Rob and Delboy but I am a wiring noob! I have the twin Heckler PCBs just don't how to adapt loom and fit these and splice into existing UK spec fog loom.
Surely there must be an easy guide for fitting PCBs to facelift lights and using existing UK fog switch somewhere?
  • 1 month later...
