ellis Posted March 13, 2017 Share Posted March 13, 2017 Morning tech bods - can somebody conform that these are indeed the correct part numbers for the UK Rear Brakes Calipers, disks, shim kit and fitting kit please (will bebusing CW fast road pads so don't need those). Many thanks UK Left Rear Caliper 47750-14280 UK Right Rear Caliper 47730-14270 UK Left Rear Brake Disk 42431-14150 UK Right Rear Brake Disk 42431-14150 UK Shim Kit Rear 04946-14030 UK Fitting Kit Rear 04948-14010 Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 13, 2017 Share Posted March 13, 2017 (edited) They all seem to be the correct numbers Edited March 13, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 13, 2017 Share Posted March 13, 2017 Just to confuse matters for you, would you not just be better off with the body of the caliper and getting the pins, pistons and seals from CW? Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 13, 2017 Share Posted March 13, 2017 Just to confuse matters for you, would you not just be better off with the body of the caliper and getting the pins, pistons and seals from CW? Pretty sure you can only buy the calipers complete with pistons and seals, they also come with the pad retaining pins as far as my memory goes Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 13, 2017 Share Posted March 13, 2017 Pretty sure you can only buy the calipers complete with pistons and seals, they also come with the pad retaining pins as far as my memory goes Oh! That's a bit naughty Quote Link to comment Share on other sites More sharing options...
