k222bye Posted March 12, 2017 Share Posted March 12, 2017 Hi guys So im replacing the following on my Supra. Water pump Thermostat (mishimoto) Cam pulleys Timing belt Seeing as im going to be in this area what else would you recommend I change? May aswell hit two or three birds with one stone. Car has 80,000 miles, oil pump looks good etc Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 12, 2017 Share Posted March 12, 2017 Crank pulley if its not been done they tend to seperate Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 12, 2017 Share Posted March 12, 2017 Cam seals, definitely. Genuine Toyota parts I take it? Quote Link to comment Share on other sites More sharing options...
fastcar Posted March 12, 2017 Share Posted March 12, 2017 Maybe oil pump and front crank seal Quote Link to comment Share on other sites More sharing options...
evinX Posted March 12, 2017 Share Posted March 12, 2017 With the timing id do, the hydraulic tensioner and tensioner bearing. Id also change the automatic tensioner and crank pulley. All those for safe measures. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 12, 2017 Share Posted March 12, 2017 Wouldn't fit a aftermarket thermostat just stick with OEM, if you do the water pump make sure you replace it with the one that has the metal impeller. Other items to consider are tensioner pulley, washer & bolt, timing belt tensioner hydraulic capsule, crank sprocket. Quote Link to comment Share on other sites More sharing options...
k222bye Posted March 13, 2017 Author Share Posted March 13, 2017 Thanks for replies. Im looking at getting this done by a garage. I wouldn't want to take a chance screwing something up plus i don't have any experience of removing cam pulleys or crank pulleys etc. So for the water pump, belt change etc. What would i be looking at paying in terms of labour costs? I have all the parts. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 13, 2017 Share Posted March 13, 2017 Who are you using? Quote Link to comment Share on other sites More sharing options...
k222bye Posted March 13, 2017 Author Share Posted March 13, 2017 Who are you using? A friend of mine said he'll do it, works for jaguar land rover. Just need a crank pulley removal tool. i see a few guys on here have made their own? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 13, 2017 Share Posted March 13, 2017 Any old pulley removed will do the job. The pulley has screw holes for you to bolt a pulley remover too. Just make sure you use the adapter that go on the end so you don't damage the treads for the crank pulley bolt. Quote Link to comment Share on other sites More sharing options...
k222bye Posted March 13, 2017 Author Share Posted March 13, 2017 Any old pulley removed will do the job. The pulley has screw holes for you to bolt a pulley remover too. Just make sure you use the adapter that go on the end so you don't damage the treads for the crank pulley bolt. I've managed to find a Toyota crank pulley remover off said friend. Will use that. Will i need the same tool for the cam pulleys? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 13, 2017 Share Posted March 13, 2017 No as they are bolted to the cams but don't need a puller to remove them. You need a locking tool to lock the cams so you can undo and then do up the cam pulleys. You have two options, get a locking tool or take the cam covers off and use the hex parts on the cams to hold the cams in place. Be seriously careful doing this though to ensure you don't damage the cams or the head i.e. if the wretch slips. Quote Link to comment Share on other sites More sharing options...
k222bye Posted March 13, 2017 Author Share Posted March 13, 2017 No as they are bolted to the cams but don't need a puller to remove them. You need a locking tool to lock the cams so you can undo and then do up the cam pulleys. You have two options, get a locking tool or take the cam covers off and use the hex parts on the cams to hold the cams in place. Be seriously careful doing this though to ensure you don't damage the cams or the head i.e. if the wretch slips. I'll get a locking tool for the cams, a sealys adjustable one. SST Toyota crank tool is going to be use to remove Crank pulley. Thank you for the input. Honestly without this forum God knows what I'd do haha. Don't want to risk damaging the cams. My friend will be doing the work. Ill be making the tea. Quote Link to comment Share on other sites More sharing options...
