NA Aerotop
Dnk
No i don't want the difference, I just need the weight of an NA aerotop, with say an empty fuel tank.
I have a local guy who i use for my recoveries but he needs to know the cars weight as its a bit close on what he can carry legally,
According to wikipedia 1510kg but it doesnt say if thus is for a hardtop or aerotop. I'd imagine an aerotop would be a little heavier so if he's got a 3.5 ton transit recovery truck he only has under 2 ton left for the truck weight fuel and his weight so he'd defineatly be over. IIRC mk5 trucks are usually about 2.2 ton empty hope this helps
  Hammer said:
Got this at home (not a lot of help, I know) but I think mine weighed in at just over the 1500kg mark, if that's any help. I can check later but won't be home 'till late this afternoon.
Thanks for that
  Hammer said:
1506kg mine weighed in at but I don't know how much fuel it had in. At a guess, pretty much half a tank as that's how much I try to keep in it most of the time. Hope that helps.
Thanks for the info :thumbs:
Half a tank would be around 30kg but i'll stick with it being over 1500kg to avoid any dramas if he were to get weighed
