boostman Posted March 7, 2017 Share Posted March 7, 2017 I recently fitted some £80 new ebay 15mm Spacers, they cracked with minimal torque so sent them back. My question is, what makes do you use, what are some tried and tested good quality ones that don't cost a fortune? Thanks Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 7, 2017 Share Posted March 7, 2017 http://www.mkivsupra.net/vbb/showthread.php?340407-H-amp-R-25mm-spacers-with-extension-bolts I can personally recommend these spacers, as most would about the brand in general. They are actually my old set and are 15mm not 25 as advertised. Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 7, 2017 Share Posted March 7, 2017 I use Novustech hubcentric slip on spacers with ARP extended studs on the front when I have my Volks fitted. 5+ years, never had an issue with them. As above, I've heard the H&R are good quality aswell. Quote Link to comment Share on other sites More sharing options...
boostman Posted March 7, 2017 Author Share Posted March 7, 2017 I use Novustech hubcentric slip on spacers with ARP extended studs on the front when I have my Volks fitted. 5+ years, never had an issue with them. As above, I've heard the H&R are good quality aswell. What's involved with fitting the extended studs? Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 7, 2017 Share Posted March 7, 2017 What's involved with fitting the extended studs? Push out the old with a stud removal tool (like a small G clamp) and then pull the new ones back in. Not a hard job, just fiddly getting the longer studs back in with the brake dust shield being in place IIRC. Quote Link to comment Share on other sites More sharing options...
bayside_supra Posted March 7, 2017 Share Posted March 7, 2017 H&r bolt ons are excellent. Really strong and surprisingly light Quote Link to comment Share on other sites More sharing options...
