Sorry! But, what's it worth?
JackyBoi
I'll try to keep it short... basically I haven't been using my Supra recently nearly as much as I used to, and I think it's maybe time to get a different car. No idea what, but that's partially because I'm not sure what the Supra is realistically worth at the moment.
Some key points about the car:
- 2001 TT6 RZ-S imported from Japan
- 1 previous owner
- Around 54,000 miles (unconfirmed - was switched from KPH to MPH during import)
- Japanese and English service history/MOT's
- Receipts from all work carried out by Whifbitz, DI Racing etc
- MOT until 20/01/2018
- Includes 'V9 SUP' private plate worth £250
Some honest points about the car:
- Paint has a few minor marks/scratches and one dent
- The map needs to be sorted out (ideally deleted and then remapped from new)
- The current diff is an open diff as the Torsen broke
- Rip in the fabric on the underside of the bonnet
And a painfully large spec list just so there's nothing left blank:
ENGINE
Stock VVTi short block and head
ARP headstuds
-12AN breathers
Whifbitz oil catch tank
New TRD engine mounts w/ brackets
New high tension front crank seal
New OEM crank pulley
New OEM cam cover seal
New OEM cam seals
New OEM oil pump
New OEM water pump
New OEM timing belt
HKS SSQV BOV
TRD oil cap
Carbon spark plug cover
Carbon bonnet dampers
Billet rad brackets
TURBOCHARGING & INDUCTION
BL Borg Warner S366 .91 A/R divided T4 turbo with billet wheel & high flow housing
Driftmotion -4AN turbo oil line feed
Powerhouse Racing -10AN turbo oil drain
DEI Fire Wrap 3000 for oil drain
DEI Heat Sheath for oil feed
Heavily modified eBay manifold; braced, re-welded & removed slag
2 x Turbosmart 38mm Ultragates
2 x screamer pipes (heat wrapped)
4" SS down pipe (heat wrapped)
4" polished intake pipe
4" K&N air filter
Whifbitz 4" front mount intercooler with custom piping
FUEL, TUNING & ECU
Syvecs S6GP ECU w/ launch control, traction control, anti-lag
Asnu 850cc injectors
Whifbitz fuel rail + fitting kit
Walbro 450lph fuel pump
Fuelab 535 FPR
Fuel pressure gauge
EXHAUST
4" turbo-back straight pipe custom made from grade 316 stainless steel
4" flexi pipe
Full decat
4" back box with a 3" inlet
Bosch LSU 4.9 wideband
DRIVETRAIN
V161 Getrag 6 speed
Spec Street Clutch Stage 2+
Spec Flywheel 6 speed
Toyota V161 gearbox oil 2L's
SUSPENSION, WHEELS, TYRES & BRAKES
BC Racing adjustable coilovers
19" Work Emotion D9R - 19x10.5 et30 rear, 19x9.5 et38 front
Michelin Pilot Super Sport rear tyres in 295/35/19
Pirelli P-zero front tyres in 255/35/19
UK front calipers, discs and pads
Jspec rear calipers, discs and pads
Braided brake lines
INTERIOR & ICE
Pioneer Double-Din Headunit
Vibe 6" speakers all-round
AEM AFR gauge
Turbosmart 2 bar boost gauge
Recaro drivers seat
Momo Mod 07 steering wheel
Carbon dash inlay
EXTERIOR
Toyota 040 super white
Stock front bumper
RMM type 2 polyurethane front lip
Blitz (modified) side skirts
OEM rear bumper
Veilside spats (modified)
TRD Half-Carbon spoiler
Window tints
Fog mod
'Turbo' badge
I'm pretty sure that's everything off the top of my head. I know everybody hates these valuation threads but I would really appreciate some input from a few people!
(I'm short on pictures of the car as it stands now but I can get some up soon)
Tough one to price, as on the one hand it was a genuine factory VVTi TT6, and has some decent branded parts on it. But it obviously needs work, the mapping especially may put people off, as may the reworked ebay manifold. I'd probably say £18k in its current condition, get the niggles sorted and you could ask quite a bit more. :)
Wow the cheek of some people that's a lowball offer. I'd give you £2k all day long
Really nice car mate glws best colour
Hmm that is an extremely tempting offer [emoji848] thanks buddy still not 100% sure though
From what I've seen mate I'd say 26-28k mate
I would have thought 26-28k is silly money for a modified one! Maybe if it was totally stock, unmolested and lived in a garage all it's life, but that certainly isn't the case ;)
28k lol absolutely no chance. 20k is reasonable and still probably wouldnt sell
I was thinking around 20k to be honest but I just wasn't sure. I paid 15k for this car (stock) back in 2014
I've been thinking the same myself - spend that bit of money getting every little issue sorted then sell it as mint as it can be. 20k would be a very nice sum to put towards a new car, decisions decisions. Thanks for the input
I know of an immaculate black 6sp single, that's recently been bought for £19k. And a TT6 being imported, with circa 50k miles on it - again for £19k.
People aren't going to pay the best part of 30 grand for a supra, unless it's something pretty special!
/QUOTE]
Fair point but this is white, stock bodied, and single turbo and face lift vvti and quite a fresh import so I just went from that
What's the spec though? Big difference between a single turbo using a piggyback and an eBay turbo kit, to one using branded parts and a decent full standalone ecu set up.
Who cares?
The only things that have really changed for the better, are turbos and management. Everything else makes no difference
/QUOTE]
Two of the most critical parts of the install. :D homers car was great, but cannot be compared favourably (performance wise) to something using much newer turbo technology, management, traction control etc.
