1600bhp with na brakes
Supraleeturbo
NA brakes should cope okay with the sort of use that car is getting, but no doubt it has uprated discs, pads and lines. It will only be used in anger in a straight line, and won't do many consecutive stops.
:yeahthat:
NA brakes are fine, only need to upgrade if you are doing track outings of spirited B-Road driving where you are constantly on the brakes and risk over heating, power output has nothing to do with what brakes are needed, it's all down to what you do with them.
I run my Stoptech 355mm front and j-spec at the rear .... but only for my races at the airport.
For the road, I install my Stoptech to the rear. The j-spec at the rear are not good for fast road usage.
I nevertheless don't drive with my 15" on the road.
Interesting :) Do you have quick release fittings on your brake lines?
