Longer/extended oil filter stud
Swampy442
Thanks mate, I see an issue though. You have to remove the stock oil cooler to fit one? I was hoping to retain the cooler and fit the plate
Ahh if you still have the stock cooler, you can fit them with the stock cooler in place, you just need the Inner bolt which I don't think Paul sells separate.
I think you can get them on eBay like the below would just have to check the thread
http://www.ebay.co.uk/itm/MOCAL-605-OIL-COOLER-SANDWICH-PLATE-3-4UNF-CENTRE-BOLT-FOR-SP1X-OTSP1X-TO-/122211856943?hash=item1c7464f22f:g:C7AAAOSwJ7RYWApn
NPs, make sure the seal on your sandwich plate is in good condition as they tend to pinch when tightened up and then the plate leaks. Dont know why people put about 4000 ft/lbs on them its only a filter and the stock on his done up only a little more than hand tight.
I can not get the one thats on my engine undone for love nor money.
Edited by T2 MSW (see edit history)
