Who has LS400 brakes?
boostman
They are Supra Do Luck lines, I think that the main problem is that the lines attach to the caliper in a weird angle due to the difference in position of the brake caliper itself.
Yes ok, so you just rotated it untill it fit so it's goes a bit tight
How long have you had it like that? Any perishing where it goes tight?
I've rerouted them around the shock absorber and fastened them with some tyraps protected with fuel hose to the upper control arm to keep them from rubbing on anything. It's only tight when I've reached lock on the steering rack so no visible damage as of yet. I'm probably gonna change them for some slightly longer braided lines eventually.
I have had ls400 fronts with Goodridge Supra lines on for over 4 years with no issues. Cant remember having an issue with fitting the brake lines.:blink: I definitely didnt have to re route anything or use tie wraps. Wouldnt that be an MOT failure?
