boostman Posted February 23, 2017 Share Posted February 23, 2017 OK iv fitted my ls400 brakes but the Braided lines don't quite fit. What has everyone else used? Can I use ls400 lines or do they have to be custom made? Thanks Quote Link to comment Share on other sites More sharing options...
P_Bazz Posted February 23, 2017 Share Posted February 23, 2017 I have mine fitted with Do Luck lines but they're also not ideal. Drivers side is fine the passenger side is always a bit under tension on the max steering angle. Quote Link to comment Share on other sites More sharing options...
boostman Posted February 23, 2017 Author Share Posted February 23, 2017 I have mine fitted with Do Luck lines but they're also not ideal. Drivers side is fine the passenger side is always a bit under tension on the max steering angle. Are they DoLuck ls400 or supra lines? Quote Link to comment Share on other sites More sharing options...
P_Bazz Posted February 23, 2017 Share Posted February 23, 2017 Are they DoLuck ls400 or supra lines? They are Supra Do Luck lines, I think that the main problem is that the lines attach to the caliper in a weird angle due to the difference in position of the brake caliper itself. Quote Link to comment Share on other sites More sharing options...
boostman Posted February 23, 2017 Author Share Posted February 23, 2017 They are Supra Do Luck lines, I think that the main problem is that the lines attach to the caliper in a weird angle due to the difference in position of the brake caliper itself. Yes ok, so you just rotated it untill it fit so it's goes a bit tight How long have you had it like that? Any perishing where it goes tight? Quote Link to comment Share on other sites More sharing options...
chrex Posted March 3, 2017 Share Posted March 3, 2017 I bent the little locator tag that is on the supra lines - no issues since Quote Link to comment Share on other sites More sharing options...
P_Bazz Posted March 3, 2017 Share Posted March 3, 2017 Yes ok, so you just rotated it untill it fit so it's goes a bit tight How long have you had it like that? Any perishing where it goes tight? I've rerouted them around the shock absorber and fastened them with some tyraps protected with fuel hose to the upper control arm to keep them from rubbing on anything. It's only tight when I've reached lock on the steering rack so no visible damage as of yet. I'm probably gonna change them for some slightly longer braided lines eventually. Quote Link to comment Share on other sites More sharing options...
jonc Posted March 6, 2017 Share Posted March 6, 2017 I have had ls400 fronts with Goodridge Supra lines on for over 4 years with no issues. Cant remember having an issue with fitting the brake lines. I definitely didnt have to re route anything or use tie wraps. Wouldnt that be an MOT failure? Quote Link to comment Share on other sites More sharing options...
