merckx Posted September 22, 2005 Share Posted September 22, 2005 MOT due tomorrow. I'm going to put that cats back on and then reset the ECU. Anyone know long it takes to learn it's new settings? Thanks Quote Link to comment Share on other sites More sharing options...
Robert Posted September 22, 2005 Share Posted September 22, 2005 pull the fuses out for about a min and then it takes about a 10 min drive to learn its new settings. Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted September 22, 2005 Share Posted September 22, 2005 I think that there's a page somewhere in the tech manual which explains the re-learning sequence that Toyota should carry out each time they reset the ECU or disconnect the battery... someone else may be able to dig it out. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 22, 2005 Share Posted September 22, 2005 My relearning sequence is: Start car. Allow it 10 seconds to work out it's not a lawnmower or an F1 car. Blip it to 2000rpm ish and listen to it struggle to catch the idle. Let it settle and repeat, note it catches the idle better. Again, let it settle and repeat. That's about it as far as I'm concerned, drive as normal. Only thing I wouldn't do is immediately chuck it up a drag strip or something -Ian Quote Link to comment Share on other sites More sharing options...
Nic Posted September 23, 2005 Share Posted September 23, 2005 Allow it 10 seconds to work out it's not a lawnmower or an F1 car. My car's dillusional and thinks it is an F1 car, although saying that yesterday it decided it was a vase of flowers and wouldn't start. It's also a bit retarded as it takes it few mins to learn that just because I let off the accelarator, that is not a cue to suddenly go back to sleep again Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 23, 2005 Share Posted September 23, 2005 I've reset the ECU several times lately, doing power runs before/after. What I've found is that you also need to turn the ignition off a couple of times as well as going through the revs with some load. Yesterday for example I took it for a few tests, and I had forgotten that I had reset the ECU the night before. After driving around for 30 miles of mixed abuse, the performance was definately below par. Then I remembered about the ECU reset, doh! Turned it off a couple of times on the side of the road, and hey presto, it loaded the amended maps.... Quote Link to comment Share on other sites More sharing options...
merckx Posted September 23, 2005 Author Share Posted September 23, 2005 Thanks everyone, much appreciated. I was thinking it would take much longer, should be able to get it running okay for the MOT. Need to drive to Halfords anyway to get a normal size front plate! Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 23, 2005 Share Posted September 23, 2005 For the MOT remember that the cat has to be really hot Quote Link to comment Share on other sites More sharing options...
