Set of 6 BOSCH EV14 935cc Injectors
Big Mark
6 x BOSCH EV14 Injectors
935cc
14mm Top feed.
Purchased from ed_jza80 18 months ago but been sat in a box on the shelf ever since I got them. But I had these cleaned to make sure they were OK.
I believe these were purchased new by ed_jza80 and never used by him either.
Comes with connectors.
£275 delivered.
:rlol:
Hi Mark,
BOSCH EV14 is the name given to these generatio of injectors.
There are many types within this group all with different lengths, mend caps and connectors, etc
Pictures and the BOSCH part number on the injector will help to verify which ones you are selling.
That way I can verify if they will work with my application to avoid any confusion.
Please can you measure the total end to end length of the injectors.
You said the top ring is a 14mm fitment, please can comfirm the external diameter of the bottom sealing ring.
Hope that helps to clarify the previous message.
Thanks
[ATTACH=CONFIG]217094[/ATTACH]
[ATTACH=CONFIG]217095[/ATTACH]
Total length = 65mm
Top and bottom o-rings measure 14mm diameter
Injector tip = 6.6mm diameter
Marking on injectors is tiny but looks like: 0280 158 117 7-01-02-10-175900
There were flow tested just before being cleaned and are 935cc
