Weird first turbo noise
JasonR24
I'm assuming that this is the wastegate chucking out air but just to be sure I made a few videos which I'll try and upload. It sounds like when the first turbo hits its max boost (0.7 to 0.8 bar), it makes a rapid air release noise kind of like a whistle. It makes the noise when you hit the first turbos pressure limit in a high gear up until the second turbo at 3500rpm when it switches over. Hopefully this is normal as everything drives fine.
