6speedmark Posted February 19, 2017 Share Posted February 19, 2017 Right this morning I decided to try and find out why my od light and slip light from time to time flash.... I have done and ecu read and it has thrown up error code 47 sub throttle control sensor??? is this common?? easy fix?? anyone no wat I do from here?? the sensor is adjustable to I do not wanna un do it as not sure how to get it back in the correct place?? Quote Link to comment Share on other sites More sharing options...
Scooter Posted February 19, 2017 Share Posted February 19, 2017 go to advanced search "overdrive light" there are loads of threads, some with a fix, some with just frustrating non fixes and living with it..... Quote Link to comment Share on other sites More sharing options...
Slam Posted February 19, 2017 Share Posted February 19, 2017 Check gear oil level Quote Link to comment Share on other sites More sharing options...
6speedmark Posted February 19, 2017 Author Share Posted February 19, 2017 To much oil in there to be fair... can that cause I it??? Quote Link to comment Share on other sites More sharing options...
Slam Posted February 19, 2017 Share Posted February 19, 2017 To much oil in there to be fair... can that cause I it??? Poss Quote Link to comment Share on other sites More sharing options...
6speedmark Posted February 19, 2017 Author Share Posted February 19, 2017 Should I check it hot or cold mate??? It's a intermittent fault Quote Link to comment Share on other sites More sharing options...
Slam Posted February 19, 2017 Share Posted February 19, 2017 Well I've just got in car , started up, then put auto lever through all gears then back to park. Switched off then check fluid level. If high. drain some out. I used a bug syringe with small tube. Put tube down dip stick hole & sucked a bit out. Quote Link to comment Share on other sites More sharing options...
Slam Posted February 19, 2017 Share Posted February 19, 2017 Then maybe reset ecu Quote Link to comment Share on other sites More sharing options...
