Planlos1988 Posted February 15, 2017 Share Posted February 15, 2017 Hello, i have a UK Spec TT AT Supra JZA80. Today i wanted to install my HKS SLD T6 but there was a problem so it cant be done.. My problem is that in the Manual of the SLD T6 are the conectors from the TRC Ecu reversed.. so in the manual the big conetcor from TRC Ecu os on the öeft and the small one on the right.. In my UK spec is the small left and the big one right bur thats not all.. on the manual the smal conector has 16pins.. ïn my uk spec it has only 12.. and the pinput from the big conector does also not fit to the pinput in the manual discribed.. can anyone help me or have a manual for the sld t6 for uk spec tt at with trc? it would be great if anyone can help me. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 15, 2017 Share Posted February 15, 2017 There is a guide on here, does that help? Quote Link to comment Share on other sites More sharing options...
Marty Posted February 15, 2017 Share Posted February 15, 2017 Why do you want to put a sld on a uk spec? I was under the impression they were made specifically for the jap spec cars. Quote Link to comment Share on other sites More sharing options...
Planlos1988 Posted February 15, 2017 Author Share Posted February 15, 2017 the sld t6 is also for eu, us and uk spec with trc.. and i whant the sld t6 to open the 250kph limit.. and thanks for the link but i dont whant to install a speedo converter. i whant to install a speed limot defencer for eu/uk spec AT with 250kph limit, also known as hks sld t6 Quote Link to comment Share on other sites More sharing options...
Scooter Posted February 15, 2017 Share Posted February 15, 2017 I know you probably want to do this properly but if you remove the traction control fuse then doesn't this delimit the car a lot easier? Quote Link to comment Share on other sites More sharing options...
Planlos1988 Posted February 15, 2017 Author Share Posted February 15, 2017 (edited) its recomendet to realy dont do that with AT and ots also not a realy good fix.. i have the TRC Ecu part no. 89631-14010 if that helps Edited February 15, 2017 by Planlos1988 (see edit history) Quote Link to comment Share on other sites More sharing options...
