Strange problem with idle
Bender
Hi. Can anybody had idea what can i do with my idle as it dosent seems right. Most of the time it stays at 1100 - 1200 rpm on the warm engine sometimes it stays how it should between 800 - 900 and ocassionaly quite rare but happend sometimes 400 - 500 rpm and when i turn car off and start it again it back to one of the two first position. Any ideas guys ?imageimage
Wysłane z mojego SM-G925F przy użyciu Tapatalka
Could be symptoms of a sticky throttle. Usually this has more to do with the throttle mechanism rather than the throttle plate/butterfly. Considering you can get an NA throttle body for cheap, I'd suggest replacing that first. If no luck, then it could be related to IACV.
