turbo/vacuum hoses
Scooter
Just wondering if anyone has a good source of the thin vacuum piping used on the sequential pipe work. The thin stuff you switch round when doing the TTC mod?
I'm finding it hard to search for it on the normal sites without getting just hoards of 'silicone' replacement type kits.
Cheers guys, when I saw the add I recognised it from buying some way back. I've also gone for some of the other stuff in the Homer link with the 3.5 & 4.5 ID hose for the smaller vsv bits.
It's those stock hoses with the very defined u bends that I think I'm going to have to possibly replace with genuine bits.
The only one that caused me a real problem was intake side up top, it's very short and makes a near 90-degree bend. With a bit of boiling in my kettle (and cutting it shorter than I thought it should be) it went on ok. If you've got weak/soft IT worker hands, you may want to allow a couple hours to push everything into place.
