charlton Posted February 9, 2017 Share Posted February 9, 2017 (edited) I've had a search and am obviously doing it wrong as there's a lot of threads on this and I cant narrow it down to what I need Is there an simple way of checking to see if the larger 4 pot brake calipers will fit my wheels without taking the wheels off? Is it possible to get an idea by measuring the clearance between the 2 pot calipers and wheel spokes? Edited February 9, 2017 by charlton (see edit history) Quote Link to comment Share on other sites More sharing options...
jim Posted February 9, 2017 Share Posted February 9, 2017 Am sure I've seen posts on the difference in size/ clearance needed. What are the wheels and their specs bud, maybe someone is running the same with uk's who could confirm if they fit? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 10, 2017 Share Posted February 10, 2017 Do you have a set of UK spec calipers already? I only ask because it is a fairly simple job to take wheel off, undo two 17mm caliper bolts, support jspec caliper and tie up brake line and then fit UK spec with two bolts and test. 10 mins max. OR are you potentially purchasing a UK set and want to double check first? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 10, 2017 Share Posted February 10, 2017 (edited) There are templates available to do this but you'd have to take the wheel off Heres one for Stoptech http://www.stoptech.com/technical-support/bbk-wheel-fitment-templates Edited February 10, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
charlton Posted February 11, 2017 Author Share Posted February 11, 2017 Thanks for the replies guys Am sure I've seen posts on the difference in size/ clearance needed. What are the wheels and their specs bud, maybe someone is running the same with uk's who could confirm if they fit? I've seen a post like this before with a template, but you think I can find it...? I'm not sure on the wheels, they were on it when I bought it and I've not investigated properly Do you have a set of UK spec calipers already? I only ask because it is a fairly simple job to take wheel off, undo two 17mm caliper bolts, support jspec caliper and tie up brake line and then fit UK spec with two bolts and test. 10 mins max. OR are you potentially purchasing a UK set and want to double check first? /QUOTE] I have them already, My concern was I don't really have the facilities to try this, although you do make it sound simple - woudln't the heat shield be a problem though? I guess I could give it a go raising the car with the jack in the boot. My concern would be getting the bolts to the right torque after, I have a wrench that will go to 24nm which I doubt will be sufficient - unless as tight as I can get it is? There are templates available to do this but you'd have to take the wheel off Heres one for Stoptech http://www.stoptech.com/technical-support/bbk-wheel-fitment-templates Thanks Dunk, that's a good call, is that not just for Stop Tech calipers, or are they similar in size? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 11, 2017 Share Posted February 11, 2017 I just get the caliper bolts as tight as possible mate without going too far by feel more than anything. I always check mine before and after spirited drives anyway. Wheel off 5 mins max. Quote Link to comment Share on other sites More sharing options...
V8KILR Posted February 11, 2017 Share Posted February 11, 2017 If you measure from the face of the disc to the inside of the wheel spokes, you need from 60mm (near center of disc ) to 65mm (outside of disc) minimum clearance to allow any chance of the big calipers clearing the wheels. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2017 Share Posted February 12, 2017 Thanks for the replies guys I've seen a post like this before with a template, but you think I can find it...? Thanks Dunk, that's a good call, is that not just for Stop Tech calipers, or are they similar in size? This was just to show you what you can do to check if a caliper will fit inside your wheels, i thought there was one for the UK fronts but i can't find it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 12, 2017 Share Posted February 12, 2017 The club should consider getting a scrap UK front and rear caliper to hire to members for checking purposes. Quote Link to comment Share on other sites More sharing options...
Scooter Posted February 12, 2017 Share Posted February 12, 2017 I have j spec fronts and uk fronts lying about I could pop them in a vice and do some measurements to add to v8killers. Does anyone currently have uk's and Lexus gs300 sport runs, if so what it the clearance like to the spokes. I currently have these wheels and j specs so could measure to the spokes to give and idea. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2017 Share Posted February 12, 2017 (edited) I had a search and found these diagrams so should be easy to use a rule and see if you have at least 20 mm from your j spec caliper to the inside of your wheels spokes, if you dont have at least that then it doesn't make any difference what the spoke profile is like Edited February 12, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 12, 2017 Share Posted February 12, 2017 Are you based in Surrey Charlton? There's plenty of local members that would be no doubt that able to lend a quick hand to check. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2017 Share Posted February 12, 2017 http://www.mkivsupra.net/vbb/showthread.php?18157-Wheels-known-to-fit-over-UK-brakes&highlight=caliper+fitment Quote Link to comment Share on other sites More sharing options...
stevegti2 Posted February 12, 2017 Share Posted February 12, 2017 my garage is in orpington S.A.S Autoworks my supra spends 99% of its life on my ramp feel free to bring a wheel up and check just let me know in advance as am fairly busy.easiest way saves the guess work Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 12, 2017 Share Posted February 12, 2017 my garage is in orpington S.A.S Autoworks my supra spends 99% of its life on my ramp feel free to bring a wheel up and check just let me know in advance as am fairly busy.easiest way saves the guess work Take him up on it, OP, this is the only way you can be really sure if things are tight, measuring in 3D is fraught with potential inaccuracies without fancy gear. Quote Link to comment Share on other sites More sharing options...
charlton Posted February 12, 2017 Author Share Posted February 12, 2017 I had a search and found these diagrams so should be easy to use a rule and see if you have at least 20 mm from your j spec caliper to the inside of your wheels spokes, if you dont have at least that then it doesn't make any difference what the spoke profile is like Cheers Dunk, that's the diagram I had seen before my garage is in orpington S.A.S Autoworks my supra spends 99% of its life on my ramp feel free to bring a wheel up and check just let me know in advance as am fairly busy.easiest way saves the guess work That would be great, thank you - you have PM Quote Link to comment Share on other sites More sharing options...
