Richie_k83 Posted February 8, 2017 Share Posted February 8, 2017 Hey all, Just wondered if anyone has a reccomendation for a performance Autobox fluid? The reason being is that I will occasionally be drifting the car and also attending some track days, so other than a decent size Transmission Oil Cooler, is there any oil folks would suggest? or is the Toyota the best available? Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted February 8, 2017 Share Posted February 8, 2017 Royal purple. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted February 8, 2017 Author Share Posted February 8, 2017 Cheers bud, will give them a look Quote Link to comment Share on other sites More sharing options...
Glanza_Mike Posted February 8, 2017 Share Posted February 8, 2017 I just used a fresh bottle of Toyota stuff and a bottle of stop slip, recommended by David P. Quote Link to comment Share on other sites More sharing options...
evinX Posted February 8, 2017 Share Posted February 8, 2017 As DavidPs mentioned hot fluid kills gearboxes, so fitting a sump of a A650e gives you more capacity = cooler fluid. In my opinion would be a good step for drifting. Quote Link to comment Share on other sites More sharing options...
Ric Posted February 8, 2017 Share Posted February 8, 2017 As DavidPs mentioned hot fluid kills gearboxes, so fitting a sump of a A650e gives you more capacity = cooler fluid. In my opinion would be a good step for drifting. You know that's not the case right? Once all the oil has heated up, you'll just have more oil at the certain temperature. Just because there's more of it doesn't mean it runs cooler. only thing what can make the oil cooler is more cooling radiators etc. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted February 8, 2017 Author Share Posted February 8, 2017 You know that's not the case right? Once all the oil has heated up, you'll just have more oil at the certain temperature. Just because there's more of it doesn't mean it runs cooler. only thing what can make the oil cooler is more cooling radiators etc. I think more Oil would take longer to heat up, but like you say, once its warm, its warm and there's just more of it. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted February 8, 2017 Author Share Posted February 8, 2017 I just used a fresh bottle of Toyota stuff and a bottle of stop slip, recommended by David P. Not sure about the additives, my primary concern is the heat. I'm running a larger cooler, but want to be extra safe with an oil that can cope Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 9, 2017 Share Posted February 9, 2017 I would run standard branded fluids and a cooler WITH A THERMOSTATICALLY CONTROLLED BYPASS! Too cold is just as bad as too hot, and in normal driving a large cooler with no `stat WILL keep the fluid too cold. Slippage in the TC and on the friction faces of brake bands and clutches is what causes heat. A higher stall converter adds a LOT more heat. US taxis came with upgraded auto boxes with higher line pressures, they forfeited ultra smooth changes for harsh ones and gained thousands and thousands more miles life from their auto boxes due to less slippage. Soft changes are akin to slipping the clutch on a manual transmission car. More heat and wear. Quote Link to comment Share on other sites More sharing options...
Scooter Posted February 9, 2017 Share Posted February 9, 2017 You know that's not the case right? Once all the oil has heated up, you'll just have more oil at the certain temperature. Just because there's more of it doesn't mean it runs cooler. only thing what can make the oil cooler is more cooling radiators etc. That's not strictly true, but more fluid in the same system will give a far smaller amount of headroom for harsh operating conditions than a cooler will, but then as Chris said too cool is bad too. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted February 9, 2017 Author Share Posted February 9, 2017 I would run standard branded fluids and a cooler WITH A THERMOSTATICALLY CONTROLLED BYPASS! Too cold is just as bad as too hot, and in normal driving a large cooler with no `stat WILL keep the fluid too cold. Slippage in the TC and on the friction faces of brake bands and clutches is what causes heat. A higher stall converter adds a LOT more heat. US taxis came with upgraded auto boxes with higher line pressures, they forfeited ultra smooth changes for harsh ones and gained thousands and thousands more miles life from their auto boxes due to less slippage. Soft changes are akin to slipping the clutch on a manual transmission car. More heat and wear. Some interesting points being made... I have the cooler now, but no thermostat. Any idea why Toyota stuff would be better than the Royal Purple fluid? or is it just a pointless spend? Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 9, 2017 Share Posted February 9, 2017 I asked this question not so long ago with our oil guru and put in REDLINE 4D, experience stuff though http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine/page20 Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted February 9, 2017 Share Posted February 9, 2017 Every company who has a machine with a name wants you to think you have to go back because it's what they recommend.... so end result they make even more money from you!!! I see this everyday with the machinery I do hydraulics on, everyone has the same thought instantly that they must use specific oils from the company who the product is bought it from not aftermarket oils, even though if you read the manual and ask for a description from the company of the oil they specify it's actually got a hidden part number or code that corresponds with another cheaper oil.....so actually you can buy better oils for cheaper if you do a little research. ☺ Quote Link to comment Share on other sites More sharing options...
andz222 Posted February 12, 2017 Share Posted February 12, 2017 i have been using using AMSOIL ATF Multi-Vehicle Synthetic Automatic Transmission Fluid amsoil signature series red bottle with no additives added takes all the abuse u throw at it Quote Link to comment Share on other sites More sharing options...
