zedhex Posted February 5, 2017 Share Posted February 5, 2017 I recently converted my Soarer to use a stand-alone ECU, so I don't need my Emanage ultimate set up any more. My new ecu has its own boost controller, and pressure sensors, so I have the following items for sale: 1. Emanage Ultimate. This one is a 'D' board revision, and it has been running fine for me for the last 2 years. It has one screw snapped off in the housing on the rear side (which does not affect how it works at all), but other than that no issues. I made 477 hp with this on a 1JZ, running a single GT3076R turbocharger. Price: £225 [ATTACH=CONFIG]216866[/ATTACH][ATTACH=CONFIG]216867[/ATTACH] 2. Plug and play harness for wiring the emanage to a 1JZGTE ECU. I believe this is a boomslang item, I know it is professionally made to a very high standard. There is one small piece cracked off the mounting (as you can see in the photo), but it has absolutely no effect on the functioning, or reliability. Price: £80 [ATTACH=CONFIG]216869[/ATTACH][ATTACH=CONFIG]216870[/ATTACH] 3. [B]1JZGTE Ecu for an non-vvti auto soarer[/b] (although I run this on my manual transmission without any issues). This is in perfect condition, and has been refurbished with new capacitors Price: £80 SOLD [ATTACH=CONFIG]216871[/ATTACH][ATTACH=CONFIG]216872[/ATTACH] 4. 3 Bar Greddy MAP sensor. This was bought new only 6 months ago, and has done only 500 mile since. It comes complete with the harness: Price: £50 [ATTACH=CONFIG]216860[/ATTACH] 5. Innovate MTX-L AFR Gauge. Complete with all wiring and a spare bezel. SOLD Price: £60 [ATTACH=CONFIG]216861[/ATTACH][ATTACH=CONFIG]216868[/ATTACH] 6. 3 Bosch 4.2 lambda sensors. . Unfortunately I know that one of them is bad - but I don't know which one! So I'm selling these as a batch, and I guarantee that 2 of them are good. Price £50 SOLD [ATTACH=CONFIG]216862[/ATTACH] 7. Oil drain pipe for GT35 on a 2JZGTE. This one is very nice quality, and is fully heat protected. I bought this in error, but it would not fit on my GT30, so it is completely unused. I paid £80 for it, but I am only asking for £45 [ATTACH=CONFIG]216863[/ATTACH][ATTACH=CONFIG]216864[/ATTACH][ATTACH=CONFIG]216865[/ATTACH] This is all good quality kit, but if you want to make me an offer, please go ahead. Link to comment Share on other sites More sharing options...
zedhex Posted February 7, 2017 Author Share Posted February 7, 2017 bump - still available Link to comment Share on other sites More sharing options...
dantheman Posted February 7, 2017 Share Posted February 7, 2017 hi does the afr gauge come with a wiring diagram and also what size diameter is the face of the gauge also many thanks Link to comment Share on other sites More sharing options...
Wonga Spar Posted February 8, 2017 Share Posted February 8, 2017 Would this cover most of the required electrical parts for a 1J conversion then? I've read the biggest annoyances with the conversion come from the electrical side (not reaching), would this solve that problem? I'm a bit under-read on the subject. Link to comment Share on other sites More sharing options...
zedhex Posted February 10, 2017 Author Share Posted February 10, 2017 hi does the afr gauge come with a wiring diagram and also what size diameter is the face of the gauge also many thanks the wiring diagram is available online here: http://www.innovatemotorsports.com/support/manual/MTX-L_print%201.2.pdf The guage is the standard 52mm size. Link to comment Share on other sites More sharing options...
zedhex Posted February 10, 2017 Author Share Posted February 10, 2017 The bit about the wiring not reaching only happens when installing to a left hand drive car. On a UK car, the 1JZ fits right in. But if you have an LHD car, then yes, this harness would probably work. Link to comment Share on other sites More sharing options...
zedhex Posted February 12, 2017 Author Share Posted February 12, 2017 wow - no interest in the emanage at this price? Only selling at this price on the supra forum. I have lowered the price on the 1JZ ECU. Link to comment Share on other sites More sharing options...
little num Posted February 13, 2017 Share Posted February 13, 2017 I'll take the stock 1j ecu please. Link to comment Share on other sites More sharing options...
little num Posted February 13, 2017 Share Posted February 13, 2017 £85 posted ok. Text me on 07751150442 Link to comment Share on other sites More sharing options...
zedhex Posted February 17, 2017 Author Share Posted February 17, 2017 I still have the emanage, the harness, the map sensor and the drainpipe. I am surprised that nobody is interested in the EMU, at that price it's a screaming bargain. Best get it now before it goes on eBay for £300. I will also be posting a set of Vibra-technics engine mounts for a 1JZ. Pics to follow Link to comment Share on other sites More sharing options...
zedhex Posted February 19, 2017 Author Share Posted February 19, 2017 Still have these Link to comment Share on other sites More sharing options...
