Laser etching - custom dash switch
mwilkinson
Update time. So I bought some satin black paint and have had a go at painting the button with the mask Mike made for me. The hardest part was making sure the mask was on in the correct location. I ended up having to draw reference marks in the masking tape to align things.
Once the mask was on the button I gave it a couple of coats of paint. A single coat looked far too thin and light would undoubtedly bleed through. I'm uncertain at this stage if even the two coats will suffice. Fingers crossed.
I took the advice ref removing the mask whilst the paint was still tacky and I'm glad I did. It was incredibly delicate work.
I'm generally happy with the result, although there was a slight variation in one of the mask lines (top). I may have to see if this can be touched up. If not I will sand it back and do it again.
I also need to apply some lacquer to seal the button and make it more durable.
I'll update once I've put the lacquer on and got the button reassembled and illuminated.
Would you be able to make a rear fog switch ?
/QUOTE]
I'd not be interested in doing this for others. It's quite an involved process, nor do I have the time to commit to such work for others.
The other issue would be obtainibg a suitable switch to use. The switch I'm using wouldn't be ideal for a fog light switch as it is a momentary push type button. The factory fog light switch isn't. So not only would you need a suitable factory alternative switch but also some electrical solution as to how the button would operate. The electrics would be quite simple, but would just be another thing.
