Tsia Posted January 30, 2017 Share Posted January 30, 2017 Evening all, Just having bit of a sort out and I found this doohicky. Anybody have a clue what it is, and if it's worth keeping? If it's any clue, it's likely left over after a single turbo conversion Quote Link to comment Share on other sites More sharing options...
evinX Posted January 30, 2017 Share Posted January 30, 2017 Vacuum sensor for a na?? actually a NA only has 1 nipple, not sure on the TTs Quote Link to comment Share on other sites More sharing options...
Tsia Posted January 30, 2017 Author Share Posted January 30, 2017 Vacuum sensor for a na?? actually a NA only has 1 nipple, not sure on the TTs I had an NA years ago, but it was before I even moved to my current home - very unlikely, but possible. Quote Link to comment Share on other sites More sharing options...
Rob W Posted January 30, 2017 Share Posted January 30, 2017 It's a VSV, can't remember which one off the top of my head. Maybe Exhaust bypass... Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 30, 2017 Share Posted January 30, 2017 Yep, it's a VSV for the twin turbo system. Can't remember which one but there's a part number on the side if you can make it out Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 31, 2017 Share Posted January 31, 2017 Looks like the tvsv (stock boost controller), normally located around the alternator area Quote Link to comment Share on other sites More sharing options...
