converting JZA80 UK-spec series 1 glass headlamp to J-spec series 2 headlamp
fastnfurious
The only difference I'm aware of will be the electric height adjustment on the series 1 set.
You will have to maintain the casing and inserts from the series 1 but just swap the plastic insert and main beam reflector from the series two set.
Basically. All you will be doing is deleting the side light pod from the series 1 insert and swapping in the series 2insert.
You can keep your glass lenses too.
Hit me up if you want to sell the series 2 casing and old lenses, the series 1 main beam reflector and the series 1 chrome inserts.
They are a straight swap, the only problem you'll have is the low beam bulbs (9006) from the UK headlights won't fit in the j-spec headlights. You will need to buy a pair of 9005 bulbs for the low beam and trim a small rib on the wiring loom connector so it'll fit.
  • 2 weeks later...
