V160 rear seal.
blythmrk
I have special low profile seals for the selector shaft (which is by far the commonest source of a leak on the back of the 6 speed Getrag), and propshaft flange seals in stock. The beauty of the low profile seals is you can carefully tap the existing seal further into the gearbox, and have TWO seals. Trying to get the original OUT is tricky, if you scratch the selector rod getting it out it will ALWAYS leak, new seals or not. E-mail if you need prices or want to order. [email protected]
Thanks rider ;)
