Dave Posted January 22, 2017 Share Posted January 22, 2017 ok so im a twat ,i read the code wrong thought i was getting 41 ,when its 14-- IGF signal. im assuming this is iginition problem coil maybe ,no spark at coil or plug anyone got any advice --thanks Quote Link to comment Share on other sites More sharing options...
np89 Posted January 22, 2017 Share Posted January 22, 2017 Thats the feedback signal to the ecu to let the ecu know the coil has fired Quote Link to comment Share on other sites More sharing options...
berg Posted January 22, 2017 Share Posted January 22, 2017 Have you checked the igniter? Quote Link to comment Share on other sites More sharing options...
Dave Posted January 22, 2017 Author Share Posted January 22, 2017 Have you checked the igniter? No will check that . - - - Updated - - - Thats the feedback signal to the ecu to let the ecu know the coil has fired /QUOTE] So do I need a new coil? Quote Link to comment Share on other sites More sharing options...
np89 Posted January 22, 2017 Share Posted January 22, 2017 No its an issue with the wiring from your ignitor to your ecu Quote Link to comment Share on other sites More sharing options...
np89 Posted January 22, 2017 Share Posted January 22, 2017 No its an issue with the wiring from your ignitor to your ecu /QUOTE] Continuity test should reveal the wire Quote Link to comment Share on other sites More sharing options...
Dave Posted January 23, 2017 Author Share Posted January 23, 2017 Continuity test should reveal the wire /QUOTE] thanks Quote Link to comment Share on other sites More sharing options...
