jonny mac Posted January 19, 2017 Share Posted January 19, 2017 hi guys, just bought myself some ls400 front brake calipers for my mkiv I was told I'd need longer bolts through the hubs to hold them on? the 12x1.25 thread pitch anyway, reason I'm here, I have found that 3/4 pistons on one caliper has split torn boots and stuck pistons the other side is perfect however I need a rebuild kit, I think I can get away with reusing the pistons. is ebay the only place? ideally I'd like a rebuild kit that I won't have to redo again in a year because of cheap rubber boots etc Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 19, 2017 Share Posted January 19, 2017 Give Chris Wilson a call, he does rebuild kits for the larger OEM Supra brakes so may be able to help you out. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2017 Share Posted January 19, 2017 http://www.biggred.co.uk do quality calliper rebuild kits. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 19, 2017 Share Posted January 19, 2017 (edited) Hi Jonny The brakes are not that hard to refurb yourself once you have a rebuild kit and know what you're doing. You can probably refurbish the pistons like I did using gradual wet and dry paper, plenty of brake cleaner and a lot of patience. As long as the outer edges and rim of the piston is smooth and not badly pitted then they'll be fine to reuse with fresh boots and piston seals. Here's a set of Lexus ones I did: http://www.mkivsupra.net/vbb/showthread.php?333923-Brake-Upgrade-Kit-Lexus-LS400-Front-Calipers-fully-refurbished And some useful refurb guides too mate. http://www.mkivsupra.net/vbb/showthread.php?332463-Brakes-Definitely-worth-checking-the-seals! http://www.mkivsupra.net/vbb/showthread.php?244873-uk-brake-refurb&highlight=brake I got my refurb kit of Chris Wilson and it's excellent. Get some stainless steel retaining pins too, makes life a lot easier when changing pads and removing calipers in future. Good link posted by Nic there and reasonable prices too. Greg Edited January 19, 2017 by Sheefa (see edit history) Quote Link to comment Share on other sites More sharing options...
jonny mac Posted January 22, 2017 Author Share Posted January 22, 2017 Hi Jonny The brakes are not that hard to refurb yourself once you have a rebuild kit and know what you're doing. You can probably refurbish the pistons like I did using gradual wet and dry paper, plenty of brake cleaner and a lot of patience. As long as the outer edges and rim of the piston is smooth and not badly pitted then they'll be fine to reuse with fresh boots and piston seals. Here's a set of Lexus ones I did: http://www.mkivsupra.net/vbb/showthread.php?333923-Brake-Upgrade-Kit-Lexus-LS400-Front-Calipers-fully-refurbished And some useful refurb guides too mate. http://www.mkivsupra.net/vbb/showthread.php?332463-Brakes-Definitely-worth-checking-the-seals! http://www.mkivsupra.net/vbb/showthread.php?244873-uk-brake-refurb&highlight=brake I got my refurb kit of Chris Wilson and it's excellent. Get some stainless steel retaining pins too, makes life a lot easier when changing pads and removing calipers in future. Good link posted by Nic there and reasonable prices too. Greg legend, thank you very much! Quote Link to comment Share on other sites More sharing options...
