All bits for an NA to run coil packs...
steve spedd
Evening all,
So my mapper has told me we can't get anymore out of my NA-T until we can control the ignition timing better. The standard dizzy isn't up to it.
I'm at 1bar and at the limits of the ignition but the rest of the build is good for 850ish.
SO! As per the guru that is Dave P I'm after:
MA-70 CPS and Cam position sensor
2JZ GTE - VVTI coil packs
I've looked on the usual places, mkiii forums and eBay but struggling to find anything.
Any help appreciated!
Many thanks,
Stephen
No mate. The MA-70 fits where the stock NA dizzy goes. As per the write up from Dave P.
But if Josh is right I'd be happy with 600hp if the dizzy can take it.
Ah i see.
Josh is correct in what he says though. Iv seen his car and his spec sheet and its all very impressive!
He uses an AEM V2 standalone
TT pistons and rods
Uprated bearings
ARP bolts throughout
NA Head Gasket
Borg Warner s300
FFIM
600cc injectors
emanage Blue
Stock Dizzy
Tial 44mm wastegate with .09 bar spring
R154 box and spec clutch
Think to get more I might need to change the. EMB and injectors
