Supra gone to SRD
fullthrottle
so last year I decided to take my UK spec car to SRD and after speaking with lee we came up with a plan, originally I was going down the big twins road but was swayed to go single as this would be a better option for my goals of 900bhp.
the work to be carried out is
complete glass out respray
suspension alignment
subframes removed and overhauled
SRD Stage 2 Built block
Mahle 86.5mm Pistons
BC Pro Rods
SRD Brace Kit with ARP hardware
New Core plugs
New squirters or squitter delete
All Machining
Balancing
Cleveite Bearings
SRD Stage 4 Head
BC stock size valves
stock size valves
Single valve springs
Titanium retails
BC locks
BC Bronze Valve guides
Port work
All machine work
SRD Stage 1 Cams
H11 Head stud kit
EGR Blank Plates
Toyota Oil Pump
Toyota Water pump
Toyota Full gasket set
Gates Timing belt
Toyota Timing belt idler wheel
SRD Billet tensioner bracket
TRD Engine Mounts
Stainless Bolts
Toyota O ring for Oil filter housing
Toyota Oil level sensor O ring
Toyota Dip stick o ring
Toyota manifold studs
Toyota Manifold nuts
RPS Triple plate carbon clutch
Fitting Kit
OS Giken 9" Diff
Fitting Kit
SRD Turbo kit with 6870 Turbo
Custom 4" Exhaust System
ETS 4" Intercooler Anodised Black
SRD Oil cooler Kit
Heater Matrix
Fuel flex
Mapping and dyno
Misc. and fluids
PHR Triple Pump Hanger
Triple Walbro pumps
Asnu 1500cc Injectors
Fuel lines and fittings
Twin Billet Filters
Aeromotive FPR Kit
Fuel pump Wiring
Toucan Display
Focal Rear speakers
Sound Deadening
Focal Front Speakers
Alpine 4 channel amp
Cabling
Bumper Undertray
Toyota seals and rubbers
I am sure there will be a few things added to the list anyhow below are some pics from when the journey started.
Nice mate. If it was me spending that much money it makes no sense to use single valve springs. Use dual. Also id just pay the extra for a 5 inch ETS. And ditch the trd engine mounts. Nice build.
Dont need dual valve springs with those cams, no point adding weight to the valve train for no reason.
The weight difference wouldnt be noticeable. I was thinking for the future. If he wanted to go further just change the cams thats it. Instead of having to take the head off. But its not my car.
Its not just the weight, its the force it takes to open the stiffer spring.
Its just pointless running really stiff springs on cams that dont need them, they are only needed on 280 cams and even then not essential unless reving high.
