Rear Toe Rods
TomWeight
Went to get a full 4 wheel geometry done last night and the guys couldn't do the rears due to seized toe bolts.
No biggy but I did get chatting to one of the guys that said he personally would consider getting rear toe rods instead of just replacing the bolts, washers etc and moving on.
Just wondering what peoples opinions are, whether it's worth going for while I'm at it or just replace the bolts and get on with it.
Worth mentioning that mine is basically upgraded stock and won't see any track life ( at least not for now ;) ).
Don't know, only took it to F1 autocentres as they were the only ones near me with the full works so haven't seen it myself.
Got a look around when I changed the wheels a week or 2 back and they didn't seem that bad but haven't had it up on the lift yet to get a proper look, might be worth a full inspection myself before I do anything you reckon?
The only way you will find out if you need a replacement arms is by getting the bolts out (cut them if need be). Out of all the arms that I took off mine, out of all the siezed bolts I removed, only one had managed to sieze itself to the inside of the arm's bush. So I had to really destroy that bush to remove it from the subframe.
Could be lucky, or not.
