Help from a fellow NA owner?
L337
So chasing a misfire I have developed over the weekend, I've been fiddling around the engine bay and I think I've knocked this vac hose off.
Can anyone with a NA (or a very good knowledge of vac hoses) tell me where it supposed to go? As now I have a bad misfire AND a super lumpy idle [ANGRY][/ANGRY]
Thanks!
As ibby says above where that vac hose comes out of you can see from the picture you took the bare metal stalk coming from the bolt where the vac hose attaches to directly below the other hose that's currently attached to the same bolt above the black bolt the problem hose is connected to.
Does that one not go the MAP sensor? The black box with the blue label (far left of the picture)? Sure it goes on the bottom of there
/QUOTE]
Thinking about it if the pipe is curling that way money says it's connnected to something in that direction.
