Fuel pump fuse /starting problems
Dave
I'm trying to sort out my problem ofnon starting and am going through the process ,I've bridged the two connectors to test the fuel flow ,pulled the pipe from the inlet manifold and got no fuel ,next step is the fuse but I can't find it in either fuse box anyone help please .
Fuel filters worth a shot, but doubt itll be completley clogged. Was it you who posted about the gas filter? did you change it, and is the vacuum sensor working?
yes was me ,got a new gas filter ,new TPS and cleaned out the ICV,there is a small amount of fuel geting through cause she fired up then stopped.if you pull the fuel in pipe from the manifold then some fuel should leak out .the car has been sitting for 3 years ive started it regually but only with a smalll amout of fuel in tank ,fuel filter is as old as the car .
