6speedmark Posted January 14, 2017 Share Posted January 14, 2017 hello all wat plugs should I put in a 1997 twin turbo bpu?? at the min plugs have been in forever and its popping / hesitant at 5000 rpm?? any advise?? Quote Link to comment Share on other sites More sharing options...
Aaronmk4 Posted January 14, 2017 Share Posted January 14, 2017 Following Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted January 14, 2017 Share Posted January 14, 2017 NGK Iridium Grade 8 or 9 I think is suitable for a BPU car. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 14, 2017 Share Posted January 14, 2017 (edited) Iridium IK22 plugs or NGK BCPR7ES. The iridium’s will last longer but will cost more. The NGK’s are a lot cheaper but will need replacing every 3k miles give or take. Sparkplug FAQ here - http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs Also, if you click the blue bpu in your first post it will give you a run down on the parts. Edited January 14, 2017 by Frank Bullitt (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2017 Share Posted January 14, 2017 (edited) http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs http://www.sparkplugs.co.uk/catalogsearch/result/?q=ik22&x=33&y=12 http://www.sparkplugs.co.uk/catalogsearch/result/?q=bcpr7es&x=29&y=14 I used copper in mine, wasn't keen on those rather brittle looking Iridium jobs, you can re gap the copper ones too, never had a problem Edited January 14, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
6speedmark Posted January 14, 2017 Author Share Posted January 14, 2017 Thank you people in will get them ordered, when people say how long a plug will last I don't really understand? ??wat determines a broken plug unless the car won't start? ?? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 14, 2017 Share Posted January 14, 2017 Copper is better from a mapping perspective as well iirc. You can order your plugs from here - http://www.opieoils.co.uk/spark-plug-and-glow-plug-lookup.aspx and don't forget to use the code M4SUPOC and get 10% Club Discount. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2017 Share Posted January 14, 2017 No idea about the mapping, i read a few stories about iridium tips breaking and basically killing your motor so use the copper type Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted January 14, 2017 Share Posted January 14, 2017 Grade 7 NGK iridium 8 or nine is overkill for BPU. I have them in stock at work but Im away atm so I cant get the part number for u lol Quote Link to comment Share on other sites More sharing options...
6speedmark Posted January 15, 2017 Author Share Posted January 15, 2017 Cheers mate if you get a chance for part number that would be great Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2017 Share Posted January 15, 2017 If you want Iridium its either the Denso IK22 or NGK BKR7EIX links in post 5 above Quote Link to comment Share on other sites More sharing options...
6speedmark Posted January 15, 2017 Author Share Posted January 15, 2017 Thank you to all Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted January 15, 2017 Share Posted January 15, 2017 Thank you people in will get them ordered, when people say how long a plug will last I don't really understand? ??wat determines a broken plug unless the car won't start? ?? Running rough ie 5 cylinders wouldn't pull you to bed blue smoke using more fuel than normal are all sighns of a dud plug Quote Link to comment Share on other sites More sharing options...
