P_Bazz Posted January 12, 2017 Share Posted January 12, 2017 Hey guys, I'm going to run a FFIM intake with an OEM Nissan Q45 throttle body on my NA-T and I noticed that the idle control on the Nissan is controlled by a waxstat on the throttle body itself. The waxstat is heated by coolant lines on the throttle body warming up the wax and lowering a plunger which in turn shuts the throttle valve. If connected properly would this system work on the Supra as well or do I need to ditch the Nissan system and use the GTE IACV setup? Link to comment Share on other sites More sharing options...
David P Posted January 13, 2017 Share Posted January 13, 2017 (edited) You can fit a Supra TPS with an adaptor you can buy and the ICV will function by ECU, or you could plumb it in and have cold start cycle by old money. Edited January 13, 2017 by David P (see edit history) Link to comment Share on other sites More sharing options...
