Q45 Throttle body idle control
P_Bazz
Hey guys,
I'm going to run a FFIM intake with an OEM Nissan Q45 throttle body on my NA-T and I noticed that the idle control on the Nissan is controlled by a waxstat on the throttle body itself. The waxstat is heated by coolant lines on the throttle body warming up the wax and lowering a plunger which in turn shuts the throttle valve. If connected properly would this system work on the Supra as well or do I need to ditch the Nissan system and use the GTE IACV setup?
