Guest Cillian Posted January 10, 2017 Share Posted January 10, 2017 Has anyone ever seen this issue before? On the knuckle part of my steering column, one the 4 small bushings had broken away leaving a lot of play on the steering column. The car was parked on a garden for a long time before i bought it whihc may be the cause of it to go brittle but i've searched here loads and can't find anyone having the issue before? I'm going to replace that section of the column, would anyone know if a Soarer column is the same Here's a pic Thanks Quote Link to comment Share on other sites More sharing options...
squiffy Posted January 10, 2017 Share Posted January 10, 2017 it feels like there is a bit of play in my steering that I've not been able to cure so I will check mine when I next get it on a ramp Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted January 10, 2017 Share Posted January 10, 2017 I'd have that bit available and in very good order, if you need it Cillian. Quote Link to comment Share on other sites More sharing options...
Guest Cillian Posted January 10, 2017 Share Posted January 10, 2017 I'd have that bit available and in very good order, if you need it Cillian. pm coming your way Quote Link to comment Share on other sites More sharing options...
Guest Cillian Posted January 10, 2017 Share Posted January 10, 2017 To update this thread for future reference Here is the part number: 45260-24070 It is discontinued by Toyota but it is the same part number for the Soarer. Quote Link to comment Share on other sites More sharing options...
