Boost Logic SFI Dampened Crank Pulley
Sheefa
Hi
I recently changed my pulley to a Fluidampr one given I got it for a discounted price hence my old pulley is up for sale. To be honest I initially thought this was a solid pulley, but it's not it is a dampened one, so I didn't need to change it after all.
It is a Boost Logic Crank Pulley which is fully dampened and lighter than stock. It only weighs 5.75lbs so is a good 20% lighter than stock and is made of both aluminium and steel. This unit will never crack. These are now discontinued and Boost Logic/ATI provide a different version.
http://www.supraforums.com/forum/showthread.php?356461-Difference-between-Boost-Logic-and-Titan-Crank-Pulley
The Boost Logic pulley has been on the car for around 8 years having covered approx 5,000 miles in that time as a guess - looking through previous owner threads etc. I have had no issues running this and it is the complete unit and comes with the required crank pulley bolt. You are able to run a stock belt with this too.
Overall condition is good, a few marks here and there but on the outer edges. I've inspect the grooves, all clear and no abrasive areas.
These used to retail at $600. I am looking for £120 delivered.
Thanks
Greg :)
