Dave Posted January 6, 2017 Share Posted January 6, 2017 has anyone got a copy of the page eg-682 with code 41 on it .thanks Quote Link to comment Share on other sites More sharing options...
keron Posted January 6, 2017 Share Posted January 6, 2017 code 41 is a Throttle Position Sensor Circuit issue... Open or short in throttle position sensor circuit throttle position sensor ECU if you google it there should be a page on images Quote Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2017 Author Share Posted January 8, 2017 (edited) code 41 is a throttle position sensor circuit issue... Open or short in throttle position sensor circuit throttle position sensor if you google it there should be a page on images sorry double post Edited January 8, 2017 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2017 Author Share Posted January 8, 2017 code 41 is a Throttle Position Sensor Circuit issue... Open or short in throttle position sensor circuit throttle position sensor if you google it there should be a page on images thanks keron would i get this code if there was a fuel problem, i think my filter/line maybe blocked ,cause whilst im turning it over no fuel is coming out of the pipe going into the engine ,i have replaced the fuel pump with the one i got from you ,thats working .ive also replaced the TPS. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted January 8, 2017 Share Posted January 8, 2017 Have you tried to bridge the b+ And fp ports and listened for fuel flowing through the rail, also did you set the tps up using a multimeter? Let me know if you want to borrow my spare ecu? Quote Link to comment Share on other sites More sharing options...
Dave Posted January 10, 2017 Author Share Posted January 10, 2017 Have you tried to bridge the b+ And fp ports and listened for fuel flowing through the rail, also did you set the tps up using a multimeter? Let me know if you want to borrow my spare ecu? Thanks balls deep going to check the fuel lines this Sunday ,have put the TPS on ,my fuel filter is original so I'm hoping its that ,will let you know mate Quote Link to comment Share on other sites More sharing options...
