Grantbonwick Posted January 6, 2017 Share Posted January 6, 2017 Alright guys I have a 1000bhp project on the go with my farther and need a few tips on the way, one being what are the best cam gears available that will bolt on my 2jzgte and withstand the power im giveing it. [COOL][/COOL] Quote Link to comment Share on other sites More sharing options...
Nic Posted January 6, 2017 Share Posted January 6, 2017 1006M-T007 JUN Cam Gears would be my choice. Quote Link to comment Share on other sites More sharing options...
Grantbonwick Posted January 6, 2017 Author Share Posted January 6, 2017 Cheers Nic big help Quote Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 7, 2017 Share Posted January 7, 2017 I could well be wrong here and so someone may well say otherwise but I've read afew times that alot of people, particularly in the US it seems prefer the stock cams. The vast majority of aftermarket cams are adjustable which obviously has its advantages but also means that when putting large amounts of power through them could result in them slipping. The stock cams are solid and so eliminates the chance of that happening. I know 2JZ engines are non interference engines but at a guess id presume that with large enough cams you could possibly change that Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 7, 2017 Share Posted January 7, 2017 with a build for 1000hp Im guessing that non interference perk could be gone with high lift cams etc Quote Link to comment Share on other sites More sharing options...
berg Posted January 7, 2017 Share Posted January 7, 2017 The PHR cam pulleys come with locking parts to eliminate risk of slipping https://www.powerhouseracing.com/product/5607/phr-billet-adjustable-locking-cam-gear-for-2jz1jz Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted January 7, 2017 Share Posted January 7, 2017 I know 2JZ engines are non interference engines but at a guess id presume that with large enough cams you could possibly change that The 2JZ is an interference engine. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 8, 2017 Share Posted January 8, 2017 The 2JZ is an interference engine. lol Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted January 8, 2017 Share Posted January 8, 2017 Well I have seen threads on other forums regarding bent valves in the 2JZ engine due to mis-timing. I assumed this meant it was an interference engine, i.e the valves and pistons can hit eachother should mis-timing occur. Unless I am misunderstanding what interference means. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 8, 2017 Share Posted January 8, 2017 2JZ is non-interference, when you add aftermarket cams that give more lift (not sure what the limit is) it becomes interference. It is also my understanding that once you start changing valves et cetera it can make the engine interference at a lower lift. Take this last bit with a pinch of salt until someone with better technical knowledge can chime in. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 8, 2017 Share Posted January 8, 2017 In stock form yes, its non interference, hence my comment re big cams Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 8, 2017 Share Posted January 8, 2017 Are stock Cam Pulleys OK for big power ? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 8, 2017 Share Posted January 8, 2017 Are stock Cam Pulleys OK for big power ? /QUOTE] Yes, just not adjustable. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 8, 2017 Share Posted January 8, 2017 Yes, just not adjustable. Thanks Nic. Good to know as I had no plans to upgrade them, don't really see the need. Quote Link to comment Share on other sites More sharing options...
